Simple report for counting IE versions
Do you have Asset intelliegence enabled in your site since v_GS_INSTALLED_EXECUTABLE View Lists information about the installed software application executables on Configuration Manager clients found through Asset Intelligence.
To get the list of Iexplore versions,use this syntax:
 select filename as "executable name",left(FileVersion,14)as "File Version",COUNT(*)as Total from v_GS_SoftwareFile where FileName='iexplore.exe'
group by FileName,FileVersion
More on Iexplore here
Thx for clearing it out :)
  • 1 year later...
Does not work for me :
Am i doing something wrong?
  • 1 month later...
Hi Kingen,
You are trying the SQL queries in WQL Query tab. 'Queries' feature uses WQL queries which is the same used for SCCM Collection queries. Repoprting feature works on SQL. The queries given above are all SQL based and you need to try the same on the Reporting feature of SCCM.
Regards,
Rajeesh
http://scorpits.blogspot.com
  • 1 month later...
Hi guys,
Im new to SQL queries. My management are asking me for a report to show what IEs we have and how many.
I need to do a custom report and point it to a collection to get the data from. How can I do this ?
Appreciate your help
Regards,
