I'm looking to setup a new System Center Current Branch to run alongside our System Center 2012 SP1 correct me if i'm wrong, as long as the site code is different i should not encounter any issues? Also, i read somewhere that i need to disable automatic site assignment but i can't seem to find that option on SCCM 2012 SP1 - could someone point me in the right direction?
Cheers!
That is potentially an option - we are currently running on Server 2008 R2 and SQL Server 2008 which needs to be upgraded to Server 2019 and SQL Server 2019. Management thinks side by side migration is better option as it means minimal downtime and less effort. Thoughts?
you can always upgrade the OS and SQL using an inplace upgrade, and that's the method I would choose and have done in the past. You need to get SCCM up to the latest version though before upgrading the operating system,
here are my old notes and this does not include the operating system upgrade (which you can do after upgrading SCCM/SQL)
