Foket Posted June 4, 2010 Report post Posted June 4, 2010 Hello everyon, I'm trying to build and capture with Windows 7. So everything goes smooth untill the Windows files are expanded and a reboot is required. 'Expanding Windows Files' reaches 100%, continues with the next bits (like the guide here says), on the background the screen appears that the pc will need to restart but the sccm window doesn't react to that. Instead it stays on the 'setup windows and configmgr' screen and this error appears : 'Task sequence : b&c win7 has failed with the error code(0x00000032)' Can't find any error in the log so not sure what's going wrong, had this error before when he skipped the installing step and went to 'join workgroup'. This was due to a wrong configuration. So why don't I get this screen ? http://www.windows-noob.com/forums/uploads/monthly_08_2009/post-1-12510175564391.jpg Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted June 4, 2010 Report post Posted June 4, 2010 Are your already running SCCM 2007 SP2? Quote Share this post Link to post Share on other sites More sharing options...
Foket Posted June 4, 2010 Report post Posted June 4, 2010 Are your already running SCCM 2007 SP2? Yes , Microsoft System Center Configuration Manager 2007 SP2 Evaluation Quote Share this post Link to post Share on other sites More sharing options...
Foket Posted June 4, 2010 Report post Posted June 4, 2010 Isn't their anyon that can help? Have to make os deployment work for an project for school (as research for a governement institution). The deadline is this weekend so kinda panicking to get this working. Would really appreciate any input as I'm really stuck on this. Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted June 4, 2010 Report post Posted June 4, 2010 I thought 0x00000032 means something like "not supported", so how does your Task Sequence look (what steps)? Did you take a look at the smsts.log? Quote Share this post Link to post Share on other sites More sharing options...
Foket Posted June 5, 2010 Report post Posted June 5, 2010 I thought 0x00000032 means something like "not supported", so how does your Task Sequence look (what steps)? Did you take a look at the smsts.log? The task sequence is the same as in the guide from this site. Yes that's kinda the problem, don't think it is showing any errors, just stopping in the middle of what it is doing. If the task sequence would just do what the windows installer is saying (rebooting) their wouldn't be any problem, and continue the task sequence of course. Quote Share this post Link to post Share on other sites More sharing options...
jamitupya Posted June 5, 2010 Report post Posted June 5, 2010 The task sequence is the same as in the guide from this site. Yes that's kinda the problem, don't think it is showing any errors, just stopping in the middle of what it is doing. If the task sequence would just do what the windows installer is saying (rebooting) their wouldn't be any problem, and continue the task sequence of course. post the log files? we cant help you without seeing what its saying :-) Quote Share this post Link to post Share on other sites More sharing options...
Foket Posted June 5, 2010 Report post Posted June 5, 2010 Yes sorry, having some problems copying them from the virtual pc but made an movie that maybe can help. Movie contains the error and the task sequence, skip to 1:25 for 'interesting part'. Also added some screenshots of the log. Hope this can help hope quality is good enough to see what's going on Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted June 5, 2010 Report post Posted June 5, 2010 There must be a different log, because this one only goes until the Partition Disk step... Quote Share this post Link to post Share on other sites More sharing options...
Foket Posted June 5, 2010 Report post Posted June 5, 2010 There must be a different log, because this one only goes until the Partition Disk step... Hmmm gonna retry and look for right one then, didn't know had more then one on that disk. Quote Share this post Link to post Share on other sites More sharing options...
Foket Posted June 5, 2010 Report post Posted June 5, 2010 Think found full log where the problem should be now, still not managing to copy it tho >< Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted June 5, 2010 Report post Posted June 5, 2010 Your problem is: Failed to resolve package source "SKS00005". This seems to be the package of your SCCM CLient. Make sure the package excists on the DP and that it is accesible for the client machine. Quote Share this post Link to post Share on other sites More sharing options...
Thomas M Posted June 7, 2010 Report post Posted June 7, 2010 Your problem is: Failed to resolve package source "SKS00005". This seems to be the package of your SCCM CLient. Make sure the package excists on the DP and that it is accesible for the client machine. Not sure if this helps, but I'll post it anyway. When I first setup the sccm site here, I reran the configuration wizard multiple times. I noticed that every time I did so, the share permissions for the SCCM client disappeared. So I put the SCCM files on a different server in order to avoid that problem. You might want to check the share permissions. Quote Share this post Link to post Share on other sites More sharing options...
Foket Posted June 7, 2010 Report post Posted June 7, 2010 Thx a lot guys, was indeed the client packages that wasn't correctly distributed. The shares that seem to go away is a problem I'm familiar with, very good tip to put them on other server, will sure try it out or atleast note it in my paper. Now just giving an error 0x0000004 when sysprep is running, probably because the client is joining the domain as specified in the task sequence, gonna try without joining now. Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted June 7, 2010 Report post Posted June 7, 2010 When you are still facing the new problem, please open a new post, as it has nothing to do with this issue. Quote Share this post Link to post Share on other sites More sharing options...
Foket Posted June 8, 2010 Report post Posted June 8, 2010 When you are still facing the new problem, please open a new post, as it has nothing to do with this issue. Okay will do, got the whole build and capture working now . Quote Share this post Link to post Share on other sites More sharing options...
