Sign in to follow this
Guys firstly I must apologise but I'm having great problems with these HTAs.
My environment is SCCM 2007 R3, Deploying OSD using Task Sequence for Win 7.
I'm trying to following this guide from the Deployment Guys (here)
I have had a few problems:
1. HTA not showing up, MININT screen was appearing until I found the guide on here to turn off.
2. HTA appears, appears to contact DB but the TS takes over and carries on building.
Whilst the guides on here are good I'm still having problems, is there, other than on here, any videos, guides and or line by line guides? I know this is probably the most easiest of tasks and I'm probably reading too much into it but pressure is on and would appreciate any further help if available.
Q's
When I'm uploading the HTA files where should they be and should they follow any special type of structure
Is there a manual way of testing these HTAs before going through the whole process of pxe over and over...
more to follow....
R
first of all why do you want to use a HTA what is your goal ?
secondly to speed up testing of the hta rather than have it in the boot image you can add it to the task sequence itself, that means that you only need to update the package the hta is part of (usually mdt files) rather than update the boot image as with the example you linked to
Hi
Thanks for the reply.
I want the HTA so that the machine can be configured to its location as they may not be built onsite. As you'll see from the link it will confirm the IP and loaction by using an MDT lookup for the default gateway.
In short to allow the engineer building the PC to confirm its name, select its location (there are 30) and finally and this is the bit I want to discover is to populate into the correct OU without any interaction.
Robert
One quick tidbit... To quickly test HTAs... Boot up WinPE on a PC, and then map a network drive to a folder containing your code. You make edits on your normal machine and then just fire them off via Command Line under WinPE. No need to update images and build new boot media or anything.
What do you mean when you say select its location?
We've got a fairly complex HTA in our environment (which needs cleaned up, but that's another story), so here are some randomish chunks of code that might help you get where you're going. If you have questions, let me know and I (and others of course) can try to help when I have a little more time...
Sub BindToActiveDirectory
'Attemping to connect to the AD environment using LDAP with alternate credentials
ReadRegistryForAD
'Editing the HKCU 1406 registry keys to avoid any ADO Security Warning message windows
objWshShell.RegWrite "HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\0\1406", 0, "REG_DWORD"
objWshShell.RegWrite "HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\1\1406", 0, "REG_DWORD"
objWshShell.RegWrite "HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\2\1406", 0, "REG_DWORD"
objWshShell.RegWrite "HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3\1406", 0, "REG_DWORD"
Log ("Attemping to bind to Active Directory using LDAP with alternate credentials")
Set objNS = GetObject("LDAP:")
'Attempting to obtain the LDAP information")
Set objRootDSE = objNS.OpenDSObject("LDAP://" & strDomainControllerFQDN & "/RootDSE", strAccountUserName, strAccountPassword, ADS_SERVER_BIND Or ADS_SECURE_AUTHENTICATION)
strDNSDomain = objRootDSE.Get("defaultNamingContext")
'Attempting to use ADO to search Active Directory
Set adoCommand = CreateObject("ADODB.Command")
Set adoConnection = CreateObject("ADODB.Connection")
adoConnection.Provider = "ADsDSOObject"
adoConnection.Properties("User ID") = strAccountUserName
adoConnection.Properties("Password") = strAccountPassword
adoConnection.Properties("Encrypt Password") = True
adoConnection.Properties("ADSI Flag") = ADS_SERVER_BIND Or ADS_SECURE_AUTHENTICATION
adoConnection.Open "Active Directory Provider"
'Replacing the original HKCU 1406 registry key information
If Not strRegistryKey0 = "" Then
objWshShell.RegWrite "HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\1\1406", strRegistryKey0, "REG_DWORD"
End If
If Not strRegistryKey1 = "" Then
objWshShell.RegWrite "HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\1\1406", strRegistryKey1, "REG_DWORD"
End If
If Not strRegistryKey2 = "" Then
objWshShell.RegWrite "HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\1\1406", strRegistryKey2, "REG_DWORD"
End If
If Not strRegistryKey3 = "" Then
objWshShell.RegWrite "HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\1\1406", strRegistryKey3, "REG_DWORD"
End If
adoCommand.ActiveConnection = adoConnection
adoCommand.Properties("Page Size") = 100
adoCommand.Properties("Timeout") = 30
adoCommand.Properties("Cache Results") = False
'Opened an ADO connection to the Active Directory Provider
End Sub
Sub ReadRegistryForAD
On Error Resume Next
'Backing up the registry keys for HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\x\1406
strRegistryKey0 = objWshShell.RegRead ("HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\0\1406")
strRegistryKey1 = objWshShell.RegRead ("HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\1\1406")
strRegistryKey2 = objWshShell.RegRead ("HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\2\1406")
strRegistryKey3 = objWshShell.RegRead ("HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3\1406")
End Sub
Function CreateNewComputerObject
Dim objContainer, objComputer
'Obtaining the AD OU object information for the OU
Set objContainer = objNS.OpenDSObject("LDAP://" & strDomainControllerFQDN & "/" & strOU, strAccountUserName, strAccountPassword, ADS_SERVER_BIND Or ADS_SECURE_AUTHENTICATION)
'Setting the AD computer account object information
set objComputer = objContainer.Create("Computer", "cn=" & strComputer)
objComputer.Put "sAMAccountName", strComputer & "$"
objComputer.Put "userAccountControl", ADS_UF_PASSWD_NOTREQD Or ADS_UF_WORKSTATION_TRUST_ACCOUNT
objComputer.SetInfo
' Will error here if the computer account object already exists
If Err then
Err.Clear
CreateNewComputerObject = 1
Else
CreateNewComputerObject = 0
End If
End Function
Function MoveADComputerObject
Dim objContainer, objConn
'Moving the " & strComputerDistinguishedName & " computer account object
objContainer.MoveHere "LDAP://" & strComputerDistinguishedName, vbNullString
If Err then
Err.Clear
MoveADComputerObject = 1
Else
MoveADComputerObject = 0
End If
End Function
