DancingFerret
Using NAS device for USMT
I wrote a very quick batch file to help Desktop Support in writing the MIG file to a NAS server. No changes were made to the network share, and it's not running IIS.
echo off
set server=LionKing
set share=statepoint
set drive=t:
set domain=private.domain
set user=sccmnetworkaccount
set password=*password*
net use %drive% \\%server%\%share% %password% /user:%domain%\%user% /persistent:no
if "%errorlevel%"=="0" echo You should now be connected to the State Migration Point.
if "%errorlevel%"=="2" echo You are already connected to the State Migration Point. Please continue.
:Menu
echo.
echo .......................................................................................................
echo Please name the folder for your Profile Capture and press enter.
echo.
set /P folder=
if "%folder%"=="exit" goto exit
if "%folder%"=="cmd" cmd
Rem The following line ignores all profile SSIDs that are absent an ntuser.dat file (but still in the registry)
SET MIG_IGNORE_PROFILE_MISSING=1
scanstate t:\%folder% /i:miguser.xml /i:migapp.xml /uel:60
if "%errorlevel%"=="0" goto complete
if "%errorlevel%" NEQ "0" echo Error: %errorlevel%
if "%errorlevel%"=="1" echo Double check that the profile capture completed please..
if "%errorlevel%"=="2" echo Double check that the profile capture completed please..
if "%errorlevel%"=="27" goto dupe
:dupe
echo A folder with the same name already exists. Please choose another.
goto Menu
:complete
echo Profile Migration should be complete. Location: \\%server%\%share%\%folder%
pause
:exit
exit
Then you would do something similar to pull the data back, but with the loadstate.exe and applicable switches. Hard Linking is much better though. :rolleyes:
