pranay bhagat
Refresh Scenario using Two TS in SCCM...
hi all,
we are working on the Refresh scenario for one of our client and using two task sequence to complete this task.
TS#1 - Stores the user data & settings to SMP.(advertisement priority HIGH)
TS#2 - Deploy Win7 & restores the data.(advertisement priority LOW,PXE boot)
TS#1 stores the states and restarts the machine and after the restart execution of TS#2 begins.
we are able to finish this task without any issue.
But we are stuck in a problem which is, consider if the TS#1 fails without saving users data and the machine restart and the TS#2 execution starts.
User data was not saved by TS#1 and so after execution of TS#2 what user gets is a machine with WIN 7 but no user data.
I just want to make sure that if TS#1 has executed successfully,then only execution of TS#2 begins.
Please suggest a way...
Pranay.
HI,
You can do this in a numbr of ways, one would be to add the Computer to a collection with TS#2 advertised using a script as the last step in TS#1, then there is no risk that the TS#2 will be executed if not TS#1 is successful. You could also use conditions in TS#2 and make sure a file is present on the C drive for instance otherwise it will fail. Not as pretty as the first suggesteion but it will work.
I normally do the first option and add it to a collection for TS#2 autimatically in the first TS.
Regards,
Jörgen
