SysAdam 0 Posted May 10, 2012 Report post Posted May 10, 2012 Hi All, I have been trolling on these forums and google trying to find a way to Deploy the latest Quicktime with SCCM 2012. I have tried creating applications from MSI's with the extracted quicktime files and setting dependecies but that didnt work. I have also tried using a script to install it (It works when running the script on the local machine with admin rights) this fails almost immediately. I am at the end of my rope. I've now wasted a day and a half trying to find a solution. Has anyone managed to do this successfuly? Did you use a legacy package or an application. Any help would be greatly appreciated. Thanks in advance SysAdam. Quote Share this post Link to post Share on other sites
jkabaseball 4 Posted May 10, 2012 Report post Posted May 10, 2012 I use a batch script and deploy it in a package. Here's my batch script: start /w msiexec /i %~dp0AppleApplicationSupport.msi /quiet /passive /norestart start /w msiexec /i %~dp0QuickTime.msi /quiet /passive /norestart ASUWISINSTALLED=0 APPLEAPPLICATIONSUPPORTISINSTALLED={0C34B801-6AEC-4667-B053-03A67E2D0415} DESKTOP_SHORTCUTs=NO QT_TRAY_ICON=NO SCHEDULE_ASUW=NO delete HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run /v "QuickTime Task" /f I have version 7.7.1 (1680.42) Deployed in SCCM 2007 and 2012 no problems. Quote Share this post Link to post Share on other sites
SysAdam 0 Posted May 11, 2012 Report post Posted May 11, 2012 Thank you very much. I was trying to avoid using packages in 2012 but it works so I will just deal with it. Thanks again. SysAdam Quote Share this post Link to post Share on other sites
jkabaseball 4 Posted May 11, 2012 Report post Posted May 11, 2012 I know you need all 3 MSI's installed for Quicktime to work. The other idea would be an application with relationships to all 3 MSI appliactions. I haven't tried it, but the relationships I have tried have been sucessful. I don't see why it wouldn't work here. Quote Share this post Link to post Share on other sites
Peter van der Woude 143 Posted May 12, 2012 Report post Posted May 12, 2012 I would indeed also use multiple applications with relationships, because keeping them separate gives you more possibilities for examples easy upgrade one part of the installation. Quote Share this post Link to post Share on other sites
nry 4 Posted May 14, 2012 Report post Posted May 14, 2012 I've just tried this and posted on a different forum with my findings. Once you extract the QT MSI's you can just deploy the QuickTime.msi file and it handles Application Support etc. You can then use GPO's to apply the quicktime.qtp file to users so you can centralise settings if you wish, as below: This one continues to be a stupid app... It stores preferences in QuickTime.qtp - great, except this is a per-user file in the individual users 'LocalLow' folder on the C: drive. If you run through the install from the exe and wait at the first prompt you should be able to search on the PC for '*.msi' and root out the extracted files when the installer runs. If you run the quicktime.msi it installs fine, no more of the 'ISSETUPDRIVEN=0' stuff from older versions, even Apple App Support installs from this one automatically. Run QuickTime and disable auto-update etc, turn off any tray icons etc. Navigate to C:\Users\YourUserName\AppData\LocalLow\Apple Computer\QuickTime and copy out the qtp file to a network share that everyone has read access to. In the user profile GPO (or relevant one applied to a user at login) add: User Configuration > Preferences > Windows Settings > Folders Add folder (Create or Update?) with the value of C:\Users\%username%\AppData\LocalLow\Apple Computer\QuickTime Add a file (Create or Update?) with the value of: Source: \\servername\share\QuickTime.qtp Destination: C:\Users\%username%\AppData\LocalLow\Apple Computer\QuickTime\QuickTime.qtp At login this folder and file is created and contains the settings you applied as your login. I tested a pupil login and ran QuickTime - it did not prompt to register etc. and on checking as an admin, the file and folder are created as required. You can silently install the QuickTime MSI though my next step is to test that this works OK - worst case you'll need an MSI for QuickTime and a second for Apple Application Support. Quote Share this post Link to post Share on other sites
h4x0r 9 Posted May 17, 2012 Report post Posted May 17, 2012 I had similar problems when we moved to 2012...I tried to keep the AAS and QuickTime MSI's as part of the same app/package, but deployment kept failing, even with proper dependencies. What I ended up doing was creating separate apps/packages for each and was able to get them to install properly that way. Quote Share this post Link to post Share on other sites
dexterrivera 0 Posted May 24, 2012 Report post Posted May 24, 2012 Got this working by creating an SCCM 2007 package that has two programs. Program 1 calls a runs VB and runs with the users permissions only when the user is logged in. Program 2 calls a CMD that in turn runs a VB script and runs with administrative permissions. The advertisment is set to download. Program 1 VB Script: (note: i push an environment variable to my machine named smssource that points to the nas path I have all of our package source files in) Set oShell = createobject ("wscript.shell") Set oFSO = createobject ("scripting.filesystemobject") Set oEnv = oShell.environment ("process") 'This creates c:\users\<userprofile>\appdata\locallow\apple computer if it doesn't already exist If Not oFSO.FolderExists (oEnv("UserProfile") & "\AppData\LocalLow\Apple Computer\") Then strNewfolder = oFSO.CreateFolder (oEnv("UserProfile") & "\AppData\LocalLow\Apple Computer\") End If 'This creates 'This creates c:\users\<userprofile>\appdata\locallow\apple computer if it doesn't already exist if it doesn't already exist If Not oFSO.FolderExists (oEnv("UserProfile") & "\AppData\LocalLow\Apple Computer\QuickTime\") Then strNewfolder = oFSO.CreateFolder (oEnv("UserProfile") & "\AppData\LocalLow\Apple Computer\QuickTime\") End If 'This copies the customized quicktime preference file to c:\users\<userprofile>\appdata\locallow\apple computer\quicktime oFSO.CopyFile oEnv("smssource") &"\Apple\QuickTime\QuickTime.qtp", oEnv("UserProfile") &"\AppData\LocalLow\Apple Computer\QuickTime\",True Program 2 CMD: Pushd %~dp0 Wscript.exe install.vbs Install.vbs: Const HKEY_CURRENT_USER = &H80000001 Const HKEY_LOCAL_MACHINE = &H80000002 strComputer = "." Apple = "C:\Windows\System32\Tasks\Apple" strKeyPath = "SOFTWARE\Microsoft\Windows\CurrentVersion\Run" strStringValueName = "QuickTime Task" Set oShell = createobject ("wscript.shell") Set oFSO = createobject ("scripting.filesystemobject") Set oEnv = oShell.environment ("process") Set oWMIService = GetObject("winmgmts:{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2") Set oReg=GetObject("winmgmts:{impersonationLevel=impersonate}!\\" & strComputer & "\root\default:StdRegProv") oShell.Run "msiexec.exe /i AppleApplicationSupport.msi /qn", ,True oShell.Run "msiexec.exe /i quicktime.msi /qn ASUWISINSTALLED=0 DESKTOP_SHORTCUTs=NO QT_TRAY_ICON=NO SCHEDULE_ASUW=NO /l* c:\windows\options\sccm\QuickTime7.71.80.42.log", ,True 'Apple creates a job for Task Scheduler for auto updates this deletes that task If oFSO.FolderExists(Apple) Then oFSO.DeleteFolder Apple End If oReg.DeleteValue HKEY_LOCAL_MACHINE,strKeyPath,strStringValueName Wscript.Quit Quote Share this post Link to post Share on other sites
