Build and Capture Failure
So I finally got the PXE to boot and install the image with updates. However it failed to Capture the image.
I created a VM PC for this which the install for the OS and updates took 2 days for some reason, think its my VM because when it loads to windows it takes it sweet time to respond to my commands.
The PXE install worked on the VM machine and boots straight into windows but I checked the folder for the capture image, but not there.
However now I am wondering how do I find out why or how the capture process failed?
How can I get a capture of this image instead of doing the whole build and capture process over again?
Is there certain log files for me to look at to see why the capture process fails?
FYI: This is my first time using SCCM and I greatly appreciate this website because it has helped me greatly from a NOOB perspective. Thanks!!
I would rather do this via SCCM instead of using that method for a .iso file and use a disk to image 40 PCs. If I can get this PXE install to work that would be GREAT!
I downloaded the drivers for the Dell E6410 and added them to the boot image which my understanding is what caused the error however it seems not to take the LAN drivers.
I saw this post about adding a software package with the drivers in the package but I do not know how to do that.
Link: http://social.technet.microsoft.com/Forums/en-US/configmgrosd/thread/7bcd82f5-2263-402b-ae62-fc32378562fc/
I found SMSTS.log
Here are the errors I received in the log.
No valid network adapter found. TSMBootstrap 7/23/2012 9:40:51 AM 1672 (0x0688)
Error getting system isolation info. Code 8027000C TSManager 7/23/2012 9:43:12 AM 1696 (0x06A0)
Remediation failed. Code 8027000C TSManager 7/23/2012 9:43:12 AM 1696 (0x06A0)
Remediation failed with error code 8027000C TSManager 7/23/2012 9:43:12 AM 1696 (0x06A0)
unknown host (gethostbyname failed) TSManager 7/23/2012 9:43:13 AM 1696 (0x06A0)
sending with winhttp failed; 80072ee7 TSManager 7/23/2012 9:43:13 AM 1696 (0x06A0)
Will retry in 4 second(s) TSManager 7/23/2012 9:43:13 AM 1696 (0x06A0)
Retrying... TSManager 7/23/2012 9:43:18 AM 1696 (0x06A0)
unknown host (gethostbyname failed) TSManager 7/23/2012 9:43:18 AM 1696 (0x06A0)
sending with winhttp failed; 80072ee7 TSManager 7/23/2012 9:43:18 AM 1696 (0x06A0)
Will retry in 12 second(s) TSManager 7/23/2012 9:43:18 AM 1696 (0x06A0)
Retrying... TSManager 7/23/2012 9:43:30 AM 1696 (0x06A0)
unknown host (gethostbyname failed) TSManager 7/23/2012 9:43:30 AM 1696 (0x06A0)
sending with winhttp failed; 80072ee7 TSManager 7/23/2012 9:43:30 AM 1696 (0x06A0)
Will retry in 23 second(s) TSManager 7/23/2012 9:43:30 AM 1696 (0x06A0)
Retrying... TSManager 7/23/2012 9:43:53 AM 1696 (0x06A0)
unknown host (gethostbyname failed) TSManager 7/23/2012 9:43:53 AM 1696 (0x06A0)
sending with winhttp failed; 80072ee7 TSManager 7/23/2012 9:43:53 AM 1696 (0x06A0)
Will retry in 45 second(s) TSManager 7/23/2012 9:43:53 AM 1696 (0x06A0)
Retrying... TSManager 7/23/2012 9:44:39 AM 1696 (0x06A0)
unknown host (gethostbyname failed) TSManager 7/23/2012 9:44:39 AM 1696 (0x06A0)
sending with winhttp failed; 80072ee7 TSManager 7/23/2012 9:44:39 AM 1696 (0x06A0)
End of retries TSManager 7/23/2012 9:44:39 AM 1696 (0x06A0)
failed to send the request TSManager 7/23/2012 9:44:39 AM 1696 (0x06A0)
Failed to send status message (80072ee7) TSManager 7/23/2012 9:44:39 AM 1696 (0x06A0)
Error calling message lib Send(). Code 0x80072ee7 TSManager 7/23/2012 9:44:39 AM 1696 (0x06A0)
Non fatal error 0x80072ee7 in sending task sequence execution status message to MP TSManager 7/23/2012 9:44:39 AM 1696 (0x06A0)
unknown host (gethostbyname failed) TSManager 7/23/2012 9:44:44 AM 1696 (0x06A0)
sending with winhttp failed; 80072ee7 TSManager 7/23/2012 9:44:44 AM 1696 (0x06A0)
End of retries TSManager 7/23/2012 9:44:44 AM 1696 (0x06A0)
failed to send the request TSManager 7/23/2012 9:44:44 AM 1696 (0x06A0)
Failed to send status message (80072ee7) TSManager 7/23/2012 9:44:44 AM 1696 (0x06A0)
Error calling message lib Send(). Code 0x80072ee7 TSManager 7/23/2012 9:44:44 AM 1696 (0x06A0)
Non fatal error 0x80072ee7 in sending task sequence execution status message to MP TSManager 7/23/2012 9:44:44 AM 1696 (0x06A0)
SHEmptyRecycleBin failed, hr=8000ffff PrepareOS 7/23/2012 9:44:44 AM 2608 (0x0A30)
Emptying Recycle bin failed, hr=8000ffff PrepareOS 7/23/2012 9:44:44 AM 2608 (0x0A30)
unknown host (gethostbyname failed) PrepareOS 7/23/2012 9:44:46 AM 2608 (0x0A30)
sending with winhttp failed; 80072ee7 PrepareOS 7/23/2012 9:44:46 AM 2608 (0x0A30)
SendResourceRequest() failed with 0x80072ee7 PrepareOS 7/23/2012 9:44:46 AM 2608 (0x0A30)
unknown host (gethostbyname failed) PrepareOS 7/23/2012 9:44:49 AM 2608 (0x0A30)
sending with winhttp failed; 80072ee7 PrepareOS 7/23/2012 9:44:49 AM 2608 (0x0A30)
SendResourceRequest() failed with 0x80072ee7 PrepareOS 7/23/2012 9:44:49 AM 2608 (0x0A30)
Failed to connect to "\\SERVERNAME.DomainName\SMSPKGC$\CLA00013" (1231). Retry in 8 seconds. PrepareOS 7/23/2012 9:44:52 AM 2608 (0x0A30)
Failed to connect to "\\SERVERNAME.DomainName\SMSPKGC$\CLA00013" (1231). Retry in 26 seconds. PrepareOS 7/23/2012 9:45:00 AM 2608 (0x0A30)
Failed to connect to "\\SERVERNAME.DomainName\SMSPKGC$\CLA00013" (1231). Retry in 19 seconds. PrepareOS 7/23/2012 9:45:26 AM 2608 (0x0A30)
Failed to connect to "\\SERVERNAME.DomainName\SMSPKGC$\CLA00013" (1231). PrepareOS 7/23/2012 9:45:45 AM 2608 (0x0A30)
Failed to connect to the share \\SERVERNAME.DomainName\SMSPKGC$\CLA00013\ with default account PrepareOS 7/23/2012 9:45:45 AM 2608 (0x0A30)
Failed to connect to "\\SERVERNAME.DomainName\SMSPKGC$\CLA00013" (1231). Retry in 15 seconds. PrepareOS 7/23/2012 9:45:45 AM 2608 (0x0A30)
Failed to connect to "\\SERVERNAME.DomainName\SMSPKGC$\CLA00013" (1231). Retry in 16 seconds. PrepareOS 7/23/2012 9:46:00 AM 2608 (0x0A30)
Failed to connect to "\\SERVERNAME.DomainName\SMSPKGC$\CLA00013" (1231). Retry in 40 seconds. PrepareOS 7/23/2012 9:46:16 AM 2608 (0x0A30)
Failed to connect to "\\SERVERNAME.DomainName\SMSPKGC$\CLA00013" (1231). PrepareOS 7/23/2012 9:46:56 AM 2608 (0x0A30)
Failed to access the share \\SERVERNAME.DomainName\SMSPKGC$\CLA00013\ with network access account PrepareOS 7/23/2012 9:46:56 AM 2608 (0x0A30)
Failed to find an available source location PrepareOS 7/23/2012 9:46:56 AM 2608 (0x0A30)
Boot Image package not found.
The system cannot find the file specified. (Error: 80070002; Source: Windows) PrepareOS 7/23/2012 9:46:56 AM 2608 (0x0A30)
The user tries to release a source directory C:\_SMSTaskSequence\Packages\CLA00013 that is either already released or we have not connected to it PrepareOS 7/23/2012 9:46:56 AM 2608 (0x0A30)
Failed to pre-stage WINPE image, hr=0x80070002 PrepareOS 7/23/2012 9:46:56 AM 2608 (0x0A30)
Unable to sysprep the machine, hr=80070002 PrepareOS 7/23/2012 9:46:56 AM 2608 (0x0A30)
Sysprep'ing the machine failed, hr=80070002 PrepareOS 7/23/2012 9:46:56 AM 2608 (0x0A30)
Failed to run the action: Prepare OS.
The system cannot find the file specified. (Error: 00000002; Source: Windows) TSManager 7/23/2012 9:46:56 AM 1696 (0x06A0)
unknown host (gethostbyname failed) TSManager 7/23/2012 9:46:56 AM 1696 (0x06A0)
sending with winhttp failed; 80072ee7 TSManager 7/23/2012 9:46:56 AM 1696 (0x06A0)
End of retries TSManager 7/23/2012 9:46:56 AM 1696 (0x06A0)
failed to send the request TSManager 7/23/2012 9:46:56 AM 1696 (0x06A0)
Failed to send status message (80072ee7) TSManager 7/23/2012 9:46:56 AM 1696 (0x06A0)
Error calling message lib Send(). Code 0x80072ee7 TSManager 7/23/2012 9:46:56 AM 1696 (0x06A0)
Non fatal error 0x80072ee7 in sending task sequence execution status message to MP TSManager 7/23/2012 9:46:56 AM 1696 (0x06A0)
The execution of the group (Capture the Reference Machine) has failed and the execution has been aborted. An action failed.
Operation aborted (Error: 80004004; Source: Windows) TSManager 7/23/2012 9:46:56 AM 1696 (0x06A0)
Failed to run the last action: Prepare OS. Execution of task sequence failed.
Task Sequence Engine failed! Code: enExecutionFail TSManager 7/23/2012 9:57:46 AM 1696 (0x06A0)
Task sequence execution failed with error code 80004005 TSManager 7/23/2012 9:57:46 AM 1696 (0x06A0)
Failed to delete directory 'C:\_SMSTaskSequence' TSManager 7/23/2012 9:57:47 AM 1696 (0x06A0)
Failed to open the task sequence key HKLM\Software\Microsoft\SMS\Task Sequence. Error code 0x80070002 TSManager 7/23/2012 9:57:47 AM 1696 (0x06A0)
Error Task Sequence Manager failed to execute task sequence. Code 0x80004005 TSManager 7/23/2012 9:57:47 AM 1696 (0x06A0)
unknown host (gethostbyname failed) TSManager 7/23/2012 9:57:48 AM 1696 (0x06A0)
sending with winhttp failed; 80072ee7 TSManager 7/23/2012 9:57:48 AM 1696 (0x06A0)
Will retry in 5 second(s) TSManager 7/23/2012 9:57:48 AM 1696 (0x06A0)
Retrying... TSManager 7/23/2012 9:57:53 AM 1696 (0x06A0)
unknown host (gethostbyname failed) TSManager 7/23/2012 9:57:53 AM 1696 (0x06A0)
sending with winhttp failed; 80072ee7 TSManager 7/23/2012 9:57:53 AM 1696 (0x06A0)
Will retry in 10 second(s) TSManager 7/23/2012 9:57:53 AM 1696 (0x06A0)
Retrying... TSManager 7/23/2012 9:58:04 AM 1696 (0x06A0)
unknown host (gethostbyname failed) TSManager 7/23/2012 9:58:04 AM 1696 (0x06A0)
sending with winhttp failed; 80072ee7 TSManager 7/23/2012 9:58:04 AM 1696 (0x06A0)
Will retry in 21 second(s) TSManager 7/23/2012 9:58:04 AM 1696 (0x06A0)
Retrying... TSManager 7/23/2012 9:58:26 AM 1696 (0x06A0)
unknown host (gethostbyname failed) TSManager 7/23/2012 9:58:26 AM 1696 (0x06A0)
sending with winhttp failed; 80072ee7 TSManager 7/23/2012 9:58:26 AM 1696 (0x06A0)
Will retry in 44 second(s) TSManager 7/23/2012 9:58:26 AM 1696 (0x06A0)
Retrying... TSManager 7/23/2012 9:59:10 AM 1696 (0x06A0)
unknown host (gethostbyname failed) TSManager 7/23/2012 9:59:10 AM 1696 (0x06A0)
sending with winhttp failed; 80072ee7 TSManager 7/23/2012 9:59:10 AM 1696 (0x06A0)
End of retries TSManager 7/23/2012 9:59:10 AM 1696 (0x06A0)
failed to send the request TSManager 7/23/2012 9:59:10 AM 1696 (0x06A0)
Failed to send status message (80072ee7) TSManager 7/23/2012 9:59:10 AM 1696 (0x06A0)
Error calling message lib Send(). Code 0x80072ee7 TSManager 7/23/2012 9:59:10 AM 1696 (0x06A0)
Non fatal error 0x80072ee7 in sending task sequence execution status message to MP TSManager 7/23/2012 9:59:10 AM 1696 (0x06A0)
Failed to create an instance of COM progress UI object. Error code 0x80040154 TSManager 7/23/2012 9:59:11 AM 1696 (0x06A0)
Timed out waiting for ccmexec service to be fully operational TSManager 7/23/2012 10:29:36 AM 1696 (0x06A0)
Failed to wait for Ccmexec service to be fully operational (0x80004005) TSManager 7/23/2012 10:29:36 AM 1696 (0x06A0)
If anyone can tell me how to add the file to this post I will because I think the formating sucks when I past from CMTrace.exe
Well, it's obviously something with the NIC drivers, like you said. Don't know why it's not working even though you added them to the boot image. Is is vmWare or Hyper-V?
Ok thanks for the Help but I figured it out. The ISO for capture media is just a disc that captures the targeted machine to SCCM. Apprarently Dell's E6410 is the issue. I was able to successfully Build and Capture on a Dell E6500 with the same network drivers.
Thanks for the help!
  • 7 months later...
I had the same exact problem with my Dell latitude E6430, it kept restarting the computer at the TS (right before the Welcome to the Task Sequence Wizard where you put your password). What I did to fix the problem was a) Go to dell driver website B) put my asset tag# c) download the network NIC driver d) in SCCM SOftware library=> Drivers=> Import drivers then i added the NIC driver to the boot x64 e) after that i ran the TS again and it worked. Turns out to be the problem with Dell Latitude E6400 Series.
