This is a basic script that will create a shortcut to Resource Explorer.
Step 1.
Copy the code below and edit the variables (marked in red)
Step 2.
Save the file as a .bat
Step 3.
Start Using it!
variables you need to change to make it work (marked in red):
1. c:
cd \SMSADMIN\bin\i386 - Point this to the folder where you have your SMS Console installed
2. %SERVER% - Change this to your primary Server (db server)
3. %SITECODE% - Change this to match your sitecode.
REM Code written by Marcus Ymsén - 2008
:start
@echo off
CLS
Title Resource Explorer
> tmp.vbs ECHO WScript.Echo InputBox( "To which Computer would you like to connect?", "Resource Explorer", "Enter Computer Name" )
FOR /F "tokens=*" %%A IN ('CSCRIPT.EXE //NoLogo tmp.vbs') DO SET dator=%%A
DEL tmp.vbs
[color="#FF0000"]c:
cd \SMSADMIN\bin\i386[/color]
SET var='%dator%'
start explore.msc -s -sms:ResExplrQuery="SELECT ResourceID FROM SMS_R_SYSTEM WHERE NAME = %var%" -sms:connection=\\[color="#FF0000"]%SERVER%[/color]\root\sms\site_[color="#FF0000"]%SITECODE%[/color]
exit
:end
Step 1.
Step 2.
Step 3.
Start Using it!
1. c:
REM Code written by Marcus Ymsén - 2008 :start @echo off CLS Title Resource Explorer > tmp.vbs ECHO WScript.Echo InputBox( "To which Computer would you like to connect?", "Resource Explorer", "Enter Computer Name" ) FOR /F "tokens=*" %%A IN ('CSCRIPT.EXE //NoLogo tmp.vbs') DO SET dator=%%A DEL tmp.vbs [color="#FF0000"]c: cd \SMSADMIN\bin\i386[/color] SET var='%dator%' start explore.msc -s -sms:ResExplrQuery="SELECT ResourceID FROM SMS_R_SYSTEM WHERE NAME = %var%" -sms:connection=\\[color="#FF0000"]%SERVER%[/color]\root\sms\site_[color="#FF0000"]%SITECODE%[/color] exit :endThis is what it looks like:
Connecting..
Result:
