dalioth
Asset Intelligence Catalog Sync (watermark problem)
I have installed a completely new SCCM 2012 with SP1 Primary Site with the following Site System Roles:
  • Application Catalog web service point
  • Application Catalog website point
  • Asset Intelligence Synchronization point
  • Component Server
  • Distribution point
  • Management Point
  • Reporting Services point
  • Site database server
  • Site server
  • Site system
  • State migration point
SCCM 2012 SP1 + SQL Server 2012 + Server 2012
Everything is working fine except Asset Intelligence snchronization point!
Status:
Asset Intelligence Catalog does not sync (never) with microsoft online service!
Error (AIUpdateSvc.log):
Asset Intelligence Catalog Sync Service Information: 0 : Tue, 22 Jan 2013 14:24:52 GMT:Error InternalError during download, watermark returned '
I would appreciate your help!
I am having the same exact problem. Fresh SCCM installation, using the SCCM 2012 with SP1 ISO. Same error in AIUpdateSvc.log
The only difference that I can see is that I am not using a proxy. My server has unrestricted, outbound access to the Internet.
dalioth,
Can you post the fix, if you find one?
I've been having this exact same issue for th epast 2 weeks, but I thought that it could be related to my VM environment (proxy server & proxy forwarder).
I have a fresh install of SCCM 2012 SP1 (official MSDN release).
thanks
The MS support technician has escalated the problem to a higher level!
He promised that the problem will be fixed until next week ;-)
Please be patient!
I have initiated a support incident through Microsoft Support! I will let you know their solution steps!
Any word from Microsoft?
Edit:
Sorry, I hadn't refreshed the page. Ignore :)
It appears that MS has fixed the issue. The last instance of ":Error InternalError during download, watermark returned" that I see is on Feb 03 2013!
I see activity on Feb 4 2013 23:50; download 349 batches.
Worked for me too. I manually synchronized the Asset Intelligence Catalog and it successfully updated for the first time since I installed SCCM.
You are right! It seems that MS has fixed the watermark problem! The last instance of ":Error InternalError during download, watermark returned" that I see is on Feb 02 2013!
