Build and Capture OSD TS not capturing
I've followed the instructions in this forum for setting up the Build and Capture OSD Task Sequence for SCCM 2012 SP1. However, the task sequence seems to end at the Windows login screen, without the Administrator user enabled, the capture operation doesn't complete, and the .wim file isn't in the save location.
I've attached the smsts.log file. Additionally, I'm trying to capture from physical media and a physical machine, not PXE and not a VM. Can anyone help and see anything that might help me out?
smsts.log
there is a problem with this Failed to resolve content for driver "Intel® 82579LM Gigabit Network Connection". Code 0x80040102 OSDDriverClient
Great, that helped a lot! I needed to pre-stage and distribute the driver package, and then everything worked. It's capturing now. Thanks for your help!
