Fray
Remove Management Point Disable
Hi all, sorry for the insistence, I have a fault with a secondary site and I need to remove the management point to as I have always done, but then I get what is in the picture, if not enabled or is happening I have not found an answer on the Internet, I ask for your help please to know what happened, took 15 days and looking like I can not delete. attached image
This happens to me all the secondary sites, not sure if this is part of the security that can be enabled and without realizing I did as part of my learning.
Thanks friend for reply and I apologize, I'm concerned and that's why I posted it again, you can uninstall, I've trying, what happens is that this is for all child sites, (Remove Management point off) and the sites are very well. Thanks for the help
Thank you for your interest and help AnyWeb. I mean point of administration for all secondary site. Only the primary site has enabled features to eliminate the role (primary site) (eliminates the management point role) for the secondary sites are all dark or disabled, does not eliminate the role (for all secondary site no more). see in the image.
  Quote
Hello. anyeweb
If you've tried and all good, you can remove the secondary site.
does your reply mean that
  • YES you have Uninstalled your secondary site successfully,
or
  • NO you could not uninstall the secondary site,
which is it ?, i'm having a hard time understanding you...
