I hope someone can help. I am running wsus sp2 on windows server 2003 R2. It hasn't worked in a year. When I launch the console, I get the error that says, "Error: Connection Error. An error occurred trying to connect the WSUS server. This error can happen for a number of reasons. Check Connectivity with the server. Please contact your network administrator (me, in this case) if the problem persists.
click Reset Server Node to try to connect to the server again."
Following this are two buttons: Reset Server Node and Copy Error to Clipboard
Clicking Reset Server Node does nothing. Rebooting the server does nothing. I've checked the event log and have found the following services to be in a state of "not working":
DSS Authentication
SimpleAuth Web Service
Client Web Service
API Remoting Web Service
Reporting Web Service
Also, one event error states: "the wsus administration console has encountered an unexpected error. this may be a transient error; try restarting the administration console. if this error persists, try removing the persisted preferencesfor the console by deleting the wsus file under %appdata%\Microsoft\MMC
There is nothing to be found in the MMC folder.
Most answers I've found online have pointed to uninstall and reinstalling WSUS, however there appears to be no simple way to do this. Has anyone found any documentation that would explain plainly how to do this?
Any help is appreciated.
Thank you,
M
