rdr222 1 Posted August 28, 2015 Report post Posted August 28, 2015 I have a 2012 R2 SP1 primary site that is servicing the main campus of the University I work at. All the site servers are located in the main campus data center. We also have a remote campus about 15 miles away from the main campus which utilizes the the servers in the main campus data center. For the most part this hasn't caused any issues, however when techs at the remote campus try to PXE boot and image a device, the TFTP portion of the boot process takes 10+ min to download the boot image as opposed to the 30 sec it takes on the main campus. Compounded when imaging multiple machines at once, 10 minutes turns into 20, 30, and so on, and is not feasible for the techs at the remote site. We have worked with our network engineers to verify that there were no problems on the network causing this difference and after A LOT of testing we determined that everything is working correctly as it is currently designed. The time difference comes from how TFTP works with the whole send 1 packet, receive 1 packet process. On the main campus, this isn't much of a problem but the minuscule bit of extra time between packets going back and forth from the main campus to the remote campus adds up to the extra time in the boot process (we actually drew out the math). So now, half of us are of the mind that we need to put a DP at the remote campus wants to start doing registry hacks and messing with DLLs to increase the TFTP window size. Is there any criteria (Physical distance, bandwidth, latency, clients managed, etc) on when it is appropriate to place a DP (or any other roles) at a remote site? Any documentation I can show about the matter would be helpful. Thanks! Quote Share this post Link to post Share on other sites
h4x0r 9 Posted August 28, 2015 Report post Posted August 28, 2015 Out of curiosity, what is keeping you from placing a DP at the remote site (aside from differing opinions)? Is it lack of a workstation/server to serve the role? Quote Share this post Link to post Share on other sites
h4x0r 9 Posted August 28, 2015 Report post Posted August 28, 2015 You might check this out, if you haven't seen it already... https://technet.microsoft.com/en-us/library/Gg712321.aspx#BKMK_DistributionPointInfrastructure Quote Share this post Link to post Share on other sites
HotdogSCCM 5 Posted August 28, 2015 Report post Posted August 28, 2015 Yeah, that link works, but it's very broad; it basically says "make decisions based on stuff!" Consider the following to help you determine the appropriate number of distribution points to install at a site: The number of clients that might access the distribution point The configuration of the distribution point, such as PXE and multicast The network bandwidth that is available between clients and distribution points The size of the content that clients retrieve from the distribution point The setting for BranchCache that when it is enabled, lets clients at remote locations obtain content from local clients DP logic is based solely on bandwidth/client limit. If you have a lot of bandwidth, there's no need for it... unless you see PXE issues. There are hard limits on DP; https://technet.microsoft.com/en-us/library/Gg682077.aspx#BKMK_SiteAndRoleScale But the limit is 4000 clients; so if you only have 1 DP (Primary) serving 4k+ clients, than one "Should" be added if only from the scalability perspective. I assume you have a fast link between main campus and the branch, so the "bandwidth" issue isn't a big deal. If PXE is truly your only pain point, I'd personally: 1) Tweak any PXE related settings/TFTP settings, ie, http://windowsitpro.com/configuration-manager/speed-sccm-tftp-performance-pxe-clients 2) Open a support case with MS outlining your issue; they may have more guidance. Assuming those two steps fail, from my perspective, I'd just drop a DP at the site and be done with it. You seem to have already spent a lot of time, both yours and networkings, on troubleshooting it. If you take your hourly rate, plus networkings time, plus time wasted not doing other things, how much has this troubleshooting already cost? 1k? 5k? 20k? Unless your budget is nil or you have a hard and fast "no more server" rule, just set up a DP at the site and be done with it. Some things aren't worth troubleshooting that hard, and this, to me, seems to be one of those. Quote Share this post Link to post Share on other sites
h4x0r 9 Posted August 28, 2015 Report post Posted August 28, 2015 True, but the main thing was in the opening paragraph of that section..."By default, a primary site server is configured as a distribution point. However, assign this role to a remote site system and remove it from the site server if possible." I got the feeling that the OP was looking for a current/best practice outline for DP placement, and their testing has already provided the data they need for considerations in those bullet points. I would be hesitant about the registry hacks, because you already know things are working correctly on the main campus...I would be concerned about the integrity of the data that's being sent across the WAN link, since that can be an issue when you make those registry modifications (though there are safe parameters for that, too). Putting an additional DP would be my first inclination, too...hence the initial question regarding why they hadn't yet. Quote Share this post Link to post Share on other sites
rdr222 1 Posted August 28, 2015 Report post Posted August 28, 2015 Out of curiosity, what is keeping you from placing a DP at the remote site (aside from differing opinions)? Is it lack of a workstation/server to serve the role? we have a small VMware cluster that we use to distribute some of the core infrastructure (DNS, DC, DHCP, etc) at the remote campus however it wasn't built with the amount of storage that placing a DP there would require and the differing opinions are from the people that write the checks for that sort of stuff. If we have some documentation or I can show that best practice says SCCM should be a part of that core infrastructure we place at a remote campus it would be helpful. Quote Share this post Link to post Share on other sites
rdr222 1 Posted August 28, 2015 Report post Posted August 28, 2015 Yeah, that link works, but it's very broad; it basically says "make decisions based on stuff!" Consider the following to help you determine the appropriate number of distribution points to install at a site: The number of clients that might access the distribution point The configuration of the distribution point, such as PXE and multicast The network bandwidth that is available between clients and distribution points The size of the content that clients retrieve from the distribution point The setting for BranchCache that when it is enabled, lets clients at remote locations obtain content from local clients DP logic is based solely on bandwidth/client limit. If you have a lot of bandwidth, there's no need for it... unless you see PXE issues. There are hard limits on DP; https://technet.microsoft.com/en-us/library/Gg682077.aspx#BKMK_SiteAndRoleScale But the limit is 4000 clients; so if you only have 1 DP (Primary) serving 4k+ clients, than one "Should" be added if only from the scalability perspective. I assume you have a fast link between main campus and the branch, so the "bandwidth" issue isn't a big deal. If PXE is truly your only pain point, I'd personally: 1) Tweak any PXE related settings/TFTP settings, ie, http://windowsitpro.com/configuration-manager/speed-sccm-tftp-performance-pxe-clients 2) Open a support case with MS outlining your issue; they may have more guidance. Assuming those two steps fail, from my perspective, I'd just drop a DP at the site and be done with it. You seem to have already spent a lot of time, both yours and networkings, on troubleshooting it. If you take your hourly rate, plus networkings time, plus time wasted not doing other things, how much has this troubleshooting already cost? 1k? 5k? 20k? Unless your budget is nil or you have a hard and fast "no more server" rule, just set up a DP at the site and be done with it. Some things aren't worth troubleshooting that hard, and this, to me, seems to be one of those. It is a fast link to the remote campus which is why the people in my dept that are against putting a DP there are against it. To them, since it's a fast link, their should be no reason to need a DP out there and there must be something wrong. We tried the reg tweaks and it didn't seem to improve performance much and i'm always hesitant to do those sort of thing because i figure if the tweak was better, it would be that way by default. I'm really trying to make the case that SCCM DP/MP should be a part of the core infrastructure that we place at remote sites like this and am looking for the documentation to back it up. Quote Share this post Link to post Share on other sites
GarthMJ 125 Posted August 28, 2015 Report post Posted August 28, 2015 Out side of PXE boot are you seeing any other issues with APP or SU deployment? How many computer are at eh branch office? Why do you need to PXE boot there at all? Why not ship the computer back to the main campus and fix them there? Quote Share this post Link to post Share on other sites
Rocket Man 40 Posted August 28, 2015 Report post Posted August 28, 2015 Like Garth has mentioned this should be based on number of clients at remote site. You have a fast link so software updates may not be throthling the WAN links presently as like software application deployments. PXE initiated OSD of PCs in mass across the WAN links with no local PXE enabled DP will hammer your link, this is expected. If you dont do that much OSD imaging at the remote site then why not go with USB deployment considering you have AD/DNS there etc replicating from Data centre. Get your techs USB built pens with your custom image, software etc.. or get the agent on the machines and stage the OSD Task sequence out to them, either of these options will leave out the slow PXE performance you are experiencing but again all depends on your remote environment i:e number of clients, how much OSD occurs etc... But at the end of the day it is a simpler solution to configure a PXE/DP for the remote site and enable for unknown computer support and F12 your machine as required to pull down a pre deployed OSD task sequence where all the software associated with it resides on a local DP where the system resides so only the local network gets throttled! Quote Share this post Link to post Share on other sites
rdr222 1 Posted September 1, 2015 Report post Posted September 1, 2015 we have our SCCM environment setup in a distributed model and scoped out for the various colleges/depts own IT teams to use so shipping them back wouldn't work since that campus is where that IT teams does it's work. I believe that having a DP at that location is the obvious way to go, i was just looking for some documentation to back up my claim as well. Quote Share this post Link to post Share on other sites
GarthMJ 125 Posted September 1, 2015 Report post Posted September 1, 2015 IMO, you already have the documentation you need. You can see that PXE is taking a long time as these remote locations, If you add a remote DP with PXE, you are sure that the time will be reduce to something that the other team will like. The only thing that I would do, is try to temporarily add a DP with PXE at that site and see to confirm the results. It will then be hard for anyone, including management to say, you are wrong. Quote Share this post Link to post Share on other sites
phil_w 0 Posted September 9, 2015 Report post Posted September 9, 2015 I work in an educational environment much like you, and see a similar effect to you with PXE boot. PXE booting multiple machines, 20 - 30+ at a time causes a dramatic slow down in boot time. We do in fact have distribution points at all of our campuses, which obviously alleviates the problem to some degree since clients across different campuses are not competing for bandwidth on the same server but even so it is slow when PXE booting a large number of machines. Having a DP and MP (seperate or colocated on the same box) at each site is definitely a very good idea, as long as 1) You ensure you set up boundary groups to ensure the clients actually use them for anything other than PXE booting. 2) You're running at least SCCM 2012 R2 SP1 / 2012 SP2, as prior to this boundary groups do not provide preferred management points to clients, they only provide distribution points and state migration points. If you're running a standalone primary site, i.e. not multiple primaries with a CAS, or secondary sites, then you'll need Cumulative Update 1 installed as well as the setting for clients to use the management point from the boundary group does not work in standalone primary sites prior to this. Point 1 being more important than point 2. However if you have a large boot image due to needing lots of drivers for a wide variety of hardware then there's only so much help moving PXE boot load onto a local DP will do. You may still find that boot times are frustratingly slow when trying to do entire computer labs even with a local DP, if so you may find it more efficient to create USB boot media instead, this is always substantially quicker than PXE. The only slight downside to this is the you need to ensure your boot media is updated any time that you update your boot image, otherwise when you start a task sequence that is associated with a more recent boot image than is on your USB drive, the TS will download the up to date boot image and reboot into that before it starts. If you're just using USB boot media, rather than stand alone task sequence media, then you can pull the sticks once booted so you don't necessarily need that many to do a whole lab. Quote Share this post Link to post Share on other sites
