you still have these issues, and until they are fixed there's no point trying to upgrade
CONFIGURATION_MANAGER_UPDATE service is starting...  $$<CONFIGURATION_MANAGER_UPDATE><08-21-2018 15:29:46.024+240><thread=2868 (0xB34)>
Microsoft System Center Configuration Manager v5.00 (Build 8540)  $$<CONFIGURATION_MANAGER_UPDATE><08-21-2018 15:29:46.024+240><thread=2868 (0xB34)>
Process ID: 2844  $$<CONFIGURATION_MANAGER_UPDATE><08-21-2018 15:29:46.024+240><thread=2868 (0xB34)>
Worker thread ID: 2868  $$<CONFIGURATION_MANAGER_UPDATE><08-21-2018 15:29:46.024+240><thread=2868 (0xB34)>
Inbox source is local on abc.com  $$<CONFIGURATION_MANAGER_UPDATE><08-21-2018 15:29:46.024+240><thread=2868 (0xB34)>
Set inbox to C:\Program Files\Microsoft Configuration Manager\inboxes\cmupdate.box  $$<CONFIGURATION_MANAGER_UPDATE><08-21-2018 15:29:46.024+240><thread=2868 (0xB34)>
This running on active site server abc.com.  $$<CONFIGURATION_MANAGER_UPDATE><08-21-2018 15:29:46.024+240><thread=2868 (0xB34)>
Inbox source is local on abc.com  $$<CONFIGURATION_MANAGER_UPDATE><08-21-2018 15:29:46.040+240><thread=2868 (0xB34)>
*** [28000][18456][Microsoft][SQL Server Native Client 11.0][SQL Server]Login failed for user 'NT AUTHORITY\SYSTEM'.  $$<CONFIGURATION_MANAGER_UPDATE><08-21-2018 15:29:46.165+240><thread=2868 (0xB34)>
*** [42000][4060][Microsoft][SQL Server Native Client 11.0][SQL Server]Cannot open database "CM_MDC" requested by the login. The login failed.  $$<CONFIGURATION_MANAGER_UPDATE><08-21-2018 15:29:46.165+240><thread=2868 (0xB34)>
*** [28000][18456][Microsoft][SQL Server Native Client 11.0][SQL Server]Login failed for user 'NT AUTHORITY\SYSTEM'.  $$<CONFIGURATION_MANAGER_UPDATE><08-21-2018 15:29:46.181+240><thread=2868 (0xB34)>
*** [42000][4060][Microsoft][SQL Server Native Client 11.0][SQL Server]Cannot open database "CM_MDC" requested by the login. The login failed.  $$<CONFIGURATION_MANAGER_UPDATE><08-21-2018 15:29:46.181+240><thread=2868 (0xB34)>
*** Failed to connect to the SQL Server, connection type: SMS ACCESS.  $$<CONFIGURATION_MANAGER_UPDATE><08-21-2018 15:29:46.181+240><thread=2868 (0xB34)>
ExecuteSqlCMUpdateInitScripts: Can't get SQL connection  $$<CONFIGURATION_MANAGER_UPDATE><08-21-2018 15:29:46.181+240><thread=2868 (0xB34)>
*** [28000][18456][Microsoft][SQL Server Native Client 11.0][SQL Server]Login failed for user 'NT AUTHORITY\SYSTEM'.  $$<CONFIGURATION_MANAGER_UPDATE><08-21-2018 15:29:46.196+240><thread=2868 (0xB34)>
*** [42000][4060][Microsoft][SQL Server Native Client 11.0][SQL Server]Cannot open database "CM_MDC" requested by the login. The login failed.  $$<CONFIGURATION_MANAGER_UPDATE><08-21-2018 15:29:46.196+240><thread=2868 (0xB34)>
*** Failed to connect to the SQL Server, connection type: SMS ACCESS.  $$<CONFIGURATION_MANAGER_UPDATE><08-21-2018 15:29:46.196+240><thread=2868 (0xB34)>
ERROR: Can not get InstallationType from SetupInfo  $$<CONFIGURATION_MANAGER_UPDATE><08-21-2018 15:29:46.196+240><thread=2868 (0xB34)>
Failed to initialize.
I always enabled Names Pipes. However, if you have an open ticket with MS, I strongly recommend that you don't continue with troubleshooting in the forums. Items I guess might conflict with item CSS suggest. This will increase the time it takes to solve the problem and may cause new problems.
issue got resolved after solving SQL server configuration manager issues.
Open a command prompt as administrator
Navigate to your SQL version’s shared directory (cd <version path>):
SQL 2008:  C:\Program Files (x86)\Microsoft SQL Server\90\Shared\
SQL 2008 R2:  C:\Program Files (x86)\Microsoft SQL Server\100\Shared\
SQL 2012:  C:\Program Files (x86)\Microsoft SQL Server\110\Shared\
SQL 2014:  C:\Program Files (x86)\Microsoft SQL Server\120\Shared\
Then run the following command:
mofcomp sqlmgmproviderxpsp2up.mof
1802 Upgrade successfully completed.
  • Thanks 1
