jnfarmer Posted June 7, 2019 Report post Posted June 7, 2019 Trying to set up the Reporting Role for SCCM. Didn't have a database show up, so I was following a guide to set up the database. The guide shows that it should be an MSSQLSERVER but I only have the option for SSRS, image below. What am I missing? Quote Share this post Link to post Share on other sites More sharing options...
GarthMJ Posted June 7, 2019 Report post Posted June 7, 2019 What is displayed is the instance name not the database name. This mean you setup your instance as SSRS Quote Share this post Link to post Share on other sites More sharing options...
jnfarmer Posted June 7, 2019 Report post Posted June 7, 2019 Where would I find that? Quote Share this post Link to post Share on other sites More sharing options...
GarthMJ Posted June 7, 2019 Report post Posted June 7, 2019 On 6/7/2019 at 5:16 PM, jnfarmer said: Where would I find that? Expand I'm not sure what you mean by this. What exactly are you trying to find? i'm not seeing anything wrong with this setup. Quote Share this post Link to post Share on other sites More sharing options...
jnfarmer Posted June 7, 2019 Report post Posted June 7, 2019 Ok, I'll bring it back to the start... I am following this guide to set up reporting, when it comes to Specify Reporting Services settings I don't get anything in the drop where it says "Reporting Services server instance" https://www.windows-noob.com/forums/topic/4550-using-sccm-2012-rc-in-a-lab-part-11-adding-the-reporting-services-point-role/ Quote Share this post Link to post Share on other sites More sharing options...
GarthMJ Posted June 7, 2019 Report post Posted June 7, 2019 When you created the SSRS SQL Server instance, did you create it with that name or did you create it with "SSRS", from the screenshot above it look like the later. Quote Share this post Link to post Share on other sites More sharing options...
jnfarmer Posted June 8, 2019 Report post Posted June 8, 2019 I'm pretty sure I just clicked through with the defaults. Quote Share this post Link to post Share on other sites More sharing options...
