Upgrade MECM2203 problem
ok it seems that it's a bug, but the button IS there you just can't see it,
try this >  use Tab to navigate and hit the Enter to launch the selection dialog, or you could use English version console to launch the wizard.
Thank you for your reply
  1. Tab and then hit Enter. You are ready to add the path. Thank you for your
  2. I found Alt +B. You can also open the path window.
  3. Is this a bug?
