Changing Boundaries Questions
I am having an issue with our client push. When I push the client to our machine it installs fine but it gets a incompatiable version and will not automatically assign the site code. I can manually set the site code as a local admin and it works fine.
I am thinking this may be a problem with the way I have the boundaries set up in SCCM. My question is, if I change the boundaries or boundary groups in SCCM will I need to extend AD again? Or does the changes automaitcally get replicated to AD?
Thanks!
AD just tells the clients where to find the SCCM server, the Boundry groups are what tells the client where they are assigned. You should be safe to change the Boundries/Groups.
Thanks for all the information. Has anyone seen this before... I can set the site manually under the local admin account, but I cannot set the site code under my domain account (which is added as an administrator locally). I get an error in the locationservices log stating an incompatabile site version was found from AD and it cannot set the site. We did a clean install of SCCM 2012 and there are no GPOs set to point to an old sccm setup.
