Sign in to follow this
jamitupya
Agent Installed but not monitoring
am i missing something?
Just performed a basic Install, click click click click click install
Windows Server 2008
Local SQL 2008 SP1
SCOM 2007 R2
Got it setup and everything, deploy the agents into my LAB, everything is showing up as not monitored... any ideas?
does the scom server account you are using in this step have local admin rights on the computers you are trying to monitor
yup, got the authentication and everything Seems to be working.
what about your firewalls ?
Hi Anyweb,
I have the same issue. I have installed the agent with domain adminstrator account.I have a domain and my scom is joined this domain and my other Computer joined the domain too. I did try to install the agent on all my computer with domain administrator account and I did not get any error during installing agent the install was successfull. What do you mean with local admin rights? Which MPs should I install for that?
Kind Regards
Nick
Hi Anyweb,
Kind Regards
Nick
Best Practise for Management of AD Groups and Local Admins is to:
1. make group on AD called "A_Server_LAdmins" &
2. use GPO to update the local Admins group making that AD group a member
3. add SCOMSERVER$ computer account in AD to be a member of AD group "A_Server_LAdmins"
4. add the SCOM Server Service Account to that also, for future use.
ideally you shold have a similar AD group for "A_Workstation_LAdmins", typically used for 3rd part AD service accounts etc and the occasional end user who needs rights for some archeic software
