lalajee
Distribution Point Job queue Manger show 86 jobs running for last 5 days
Under the Distribution Point Job queue Manger it show that 86 jobs are running for last 5 days.
I have checked Distmgr, PKGXfermgr log on primary server and SMSDPPRov log on DP but I dont see any issue. The DP which is showing 86 package running is Pull DP
Our Setup
  • CAS with 3 Primary Site With DP and Pull DP
My question is
  • Does it mean 86 Jobs are replicating to this server or is this server replicating 86 Job to other DP's
  • What logs i can check to see why it has 86 Job running for last 5 days.
  • Which server do I need check the logs from
Please advice
have you tried looking at your distribution point configuration status in Monitoring ? what does that tell you
also, why do you have a CAS and three primaries, are you managing 150,000 clients (or more) ?
