# Distribution Point
SCCM was moved from on prem to Azure cloud now building machines do not work properly
Distribution Point not showing after installing the DP site system role
- 9 comments
- 18767 views
Distribution Point install failure
- 2 comments
- 13902 views
How can I setup a Distribution Point in ConfigMgr 2012 on a Windows 7 computer?
Dietmar ·- 51 comments
- 202239 views
SCCM Configuration Manager - Upgrade - Site Systems, DP, Client
Management Point/Distribution Point mofcomp issue
drewz99 ·
- 14 comments
- 18868 views
Downloading (0% complete)
- 3 comments
- 6151 views
azure dp - clients stuck at 0 %
Jaekt ·
- 6 comments
- 10907 views
Subject Alternative Names for Distribution Point Certificate?
- 2 comments
- 2979 views
Slow OSD with only one Distribution Point (Virtual Machine)
- 10 comments
- 7026 views
WIM image not updating on the distribution point
- 4 comments
- 5438 views
Planning for 1 primary server SCCM 2012 and 1 distribution point
Currnet Branch; To BITS or not to BITS
DB3 ·
- 1 comment
- 3106 views
Impossible to Add Application to a DP after remove it from DP content properties
SCCM 2012 DP stuck "starting to process content"
- 2 comments
- 11648 views
Multiple DP & MP impacts on Boot Media
shandfin ·
- 1 comment
- 2992 views
Task sequence cannot run because the program files cannot be located on a distribution point
Misreporting DP's
- 6 comments
- 6962 views
Site System Design Verification - Am I Crazy?
BzowK ·
- site
- lan
- design
- distribution point
Tagged with:
- 5 comments
- 3665 views
Scheduled Updates Issue - not updating to DP
rkh ·
- 6 comments
- 5476 views
